RE: Ground clearance for on-roads
Here's a trick i learned, get a large marker and paint the bottom of the chassis. Now set your ride height to about 10mm front and rear. Now run the car for about 5-10 min. then check the chassis (if you have no scrapes lower the car), (if you have some scrapes your close) and (if if have alot of scrapes raise the car).
