Hyperion USB adapted question
I just bought the Hyperion Duo and find I should probably upgrade the firmware (V1.2) to the current 1.7. Can anyone tell me what is in the USB adapter? If it is a simple plug converter I should be able to modify a standard USB cable to work but if there are any active or exotic components in it I guess I am looking at buying one. This is the adapter piece that interfaces the USB cable to the servo type connecter adapter. Looks to be on a small PC board and probably has a mini USB conn on one end and a servo style connector on the other end.
Thanks -Rob-
