RCU Forums - View Single Post - CMP BF109F BUILDING THREAD
Old 09-12-2008 | 02:33 PM
  #160
Hot Rod Todd's Avatar
Hot Rod Todd
Default RE: CMP BF109F BUILDING THREAD
I have quite a few warbirds ARFs including a bunch of CMP's, and this is the best looking I have seen. The controls surfaces have scale type insets and use good hinges, not CA hinges. I may add a bit of color to set it off, enlarge the wheel wells a bit for bigger tires, but other than that it is very good as it is. Most of the Mods are people wanting to make something special out of an ARF, but they are not required. The plane will most likely fly better without a bunch of weight adding scale mods, and look just a bit less scale. If you see one out of the box you will not be disappointed, tough to beat for the price. If you don't add a bunch of weight it should be a great flier too.
Contact Alex at A-K models, he has a bunch in stock for $276.
Some of my Warbird Fleet.
