RCU Forums - View Single Post - Lesson learned: use the threadlocker
Old 09-12-2008 | 03:23 PM
cappaj1's Avatar
cappaj1
Default RE: Lesson learned: use the threadlocker
ORIGINAL: JohnW
Thread lock is good for most of our metal to metal connections. I should not however be used on work or plastic connections, so I'm a bit curious about the servo screws you said were missing. Is the servo screwed into wood/plastic, or a metal block?
Wooden servo trays that came installed in the Sig Kadet LT-40.
