RCU Forums - View Single Post - Why not a Webra engines thread?
Old 09-13-2008 | 12:15 AM
DarZeelon's Avatar
DarZeelon
Default RE: Why not a Webra engines thread?
ORIGINAL: MTK
Dynamix carb? 25 years ago when I had mine, I couldn't get the blasted thing sorted out.
Matt,
The Dynamix™ carburettor needs a relatively high fuel pressure to function properly.
A fuel pump is almost an imperative requirement, since exhaust-pressure is relatively low.
Getting it high enough would require so much back-pressure, the engine's performance would be compromised.
The manual says this, but most people follow this rule; "Only after all else failed, RTFM"...
That's 'Read The Manual' for you...
