RCU Forums - View Single Post - Frustrated! Electric/Aluminum prop adapters
Old 09-13-2008 | 09:38 AM
Dsegal
Default RE: Frustrated! Electric/Aluminum prop adapters
Are you sure you have the right size of adapter? What type is it- setscrew or split collet? I have never had an aluminum adapter strip out even with high force on the prop wrench. And what seems to be slipping- the prop on the collet or the entire prop and collet assembly on the motor shaft.
