RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 09-13-2008 | 11:48 AM
  #7752
crashcrash
Default RE: Wheeeeeeee.......... Blade CP!
ORIGINAL: mikey1964
Vic~you want to fly something crazy try flying a 30 size extra crashed my first time out because i had the throws set to high,tried doing a looped and it snaped at about 20 feet saved it and janked on the stick and it snaped again so i chopped the throttle and put it in, but after i set them right i could fly it with a lot of speed on takeoff and landing stalls very easy, been flying everything from small electrics to 1/4 scale for 10 years so i think with a little help i could fly that little sceamer[X(] thanks for the info mike
Hey....I know you can fly it, that's not the problem. The build and setup are what will kill you if you do it wrong. If I had this thing at 100% D/R.....I would have smashed it for sure. If you get one...get with me. The motor as stock is very sufficient, but battery should be minimal 2150 3S 20C My helicopters use 2200 3S 20-30C, and it works WELL in the F-16, but I had to set the fan unit back 1.5" more than if I'd used a lighter battery. A tick nose heavy, but I can deal with it.
