RCU Forums - View Single Post - CMP BF109F BUILDING THREAD
Old 09-13-2008 | 12:18 PM
  #175
BQuartucy
Default RE: CMP BF109F BUILDING THREAD
Continuation of gear installation....
#5, installs the gear retract mechanism
#6 is a mockup of the gear wire
#7, is a 4" robart wheel
#8, is the gear in the retracted position.
This was done to place the;
1. The pivot point of the gear in the scale position on the wing.
2. Position the axel center even with the wing root as shown is most 3 views.
3. Retract the gear assembly so the wheel would fit between the leading edge and the main spar.
ID:	1032373   Click image for larger version
ID:	1032374   Click image for larger version
ID:	1032375   Click image for larger version
