Thanks. I wonder if the motor mount would work on the .5 and allow us to pull that pipe in closer.
ORIGINAL: TheKaiman
It seems like it would fit. Because the hole for the cooling is in the middle I can't get the body all the way on. It does look like it would work if you cut the hole where it normally would be.
