RCU Forums - View Single Post - CMP BF109F BUILDING THREAD
Old 09-14-2008 | 09:27 AM
  #182
SCALECRAFT's Avatar
SCALECRAFT
My Feedback: (13)
Default RE: CMP BF109F BUILDING THREAD
BQ
I can post only 2 at a time. More will time out.
I use a contour gauge to get the top of the rib shape and trace it onto the top of the pattern, in this case foam sheet
I use 1/16" foam from my kids craft box to get a rough shape of the rib. One can use card stock as well. It is easy to place up against the original ribs. After you get a shape you're happy with, trace it onto the wood you will use for the rib. And rough cut a rib.
ID:	1033050   Click image for larger version
