RCU Forums - View Single Post - Muffler threads are stripped; how hot does an engine get
Old 09-14-2008 | 01:48 PM
w4kv's Avatar
w4kv
Default RE: Muffler threads are stripped; how hot does an engine get
Thanks for the tip on the Duratrax.
Thanks for the other tips, but I've already done my makeshift repair.
After seeing how much a new muffler and header cost (~$56), I decided to fiddle with my old one. I degreased the header and the nonexistent threads on the muffler. I had already drilled the muffler and header, and I used the holes for a 4-40 screw and double nut + Loctite. Then I tightened the header's retainer screw (+ Loctite) down against the muffler. No vibration now! And finally, I used a 19 g retention wire.
On the engine side, I degreased and used high temp Loctite.
When it falls off next time, I get a new muffler/header and follow your suggestions.
The next 4-str engine I get will have the pump.
