RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 09-14-2008 | 06:31 PM
  #7805
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Jay,
I thought you may get a kick out of it...
Bob's,
Got a tiny problem on the HBK2. I think it's either a tail servo going sour on me. or the telebee gyro.
There is absolutely no binding anywhere. You know me on SET-UP. At take off and in a solid hover, everything is okay. If I make a snap 90 degree turn, left or right. The tail will pulse back and forth for about 2 seconds and then be solid again.. Not a tail wobble all the time. The pulsing of the tail is only 1/2 inch in each direction at most. Happens too, on a piro.. I've adjusted the gyro screw/srew(JAY) left and right to no avail. Hmmm, what's your best guess, gyro or servo, has to be one of them suckers.
On the Lama V4, I had to order a bottom (A) gear. I heard some weird nose and found that 2 teeth on the gear were worn.. Not bad actually, I have over 100 flights on it.
Dave / Choppersrule
