RCU Forums - View Single Post - CG confusion
Thread: CG confusion
Old 09-14-2008 | 09:52 PM
grimmy55
Default RE: CG confusion
the best and surest way is to get a peice of string ,tye one end to the end of tail and the other end to prop nut ,pickup plane by the string so that you form a triangle get the plane level this way and then drop a peice of string vertical down from where you are holding it and at the point where the vertical is on the plane that is the balance point ,,hope you get my drift
