RE: Wheeeeeeee.......... Blade CP!
I've just up graded my CP Pro with E-Flight Heading Lock G90 gyro, brushless motor, and Spektrum receiver. The setting for the gyro was tested low 45 to 75 on the gain with the 3 and 1 set to minimum lowest adjustment. And the gyro set to 100% highest setting. At the low setting as I increased power the tail spins to the left, at the high setting it will not turn right. It doesn't seam to lock on a heading. (or I'm expecting to much) Do I need a smaller tail rotor blade, a larger motor? This is my first heli I've been flying it for 7 months and just started to do 3-D. Add this is the first time I've programed a heli. Lots of question with setting up my JR 9303. It seams that the travel adjustment is set very high or low so I can us the trim setting without running out of adjustment. I was sure that at 50% thro I had the swash- plate leveled. ???
But still required alot of trim. ?? I'm over looking something and need help.
George
