RE: Helicopter Problems
Yes I was running it close to the ground and I took it up to like 5 or 6 feet and it seemed more stable but then I crashed it because I don't know how to fly one. My tail boom( i think thats what it is called) came loose and swivels even when it is not off the ground yet should I just ca glue it back into place? If the blades are chopped up at the end can I still use them because if i switch them again I will just ruin another set. I am using the foam blades with carbon fiber rods for reinforcement and the plastic shrink wrap type stuff on the outside. Thanks
