RE: Norvel .40
I've had a couple Norvel .40's but never seen that happen. Make sure you are getting the prop nut good and tight. Don't worry, it is hardened steel and will take a lot of torque.
You can also use a little blue Loktite to hold the stud into the crankshaft.
