Okay,
I've started the building/conversion of the World Models Tamecat. I am now going to use a BP Hobbies BP-A4120-7 motor with a BP-80A-LV ESC. I'm still going to use my Flightpower 4900mah 6S battery. According to a friend who works for Flightpower, and knows a whole lot more than me, I should try an 11x8 or 12x6 prop. That will give me more rpm and the ground clearance I need. The kit is first rate and the contstruction looks like it was designed for electric conversion. The fuse structure is open all the way through so if I open the rear of the fuse, where the fake exhaust outlets are, that will give me my air exit. I'm going to open the bottom of the cowl and widen the hole on the firewall to accomodate an air inlet channel.
I did convert the wing hold downs to 10x24 nylon bolts instead of the weak looking skinny metal bolts that were in the kit. The fuel tank area accomodates the Flightpower 6s with no modification. I will have to build a small shelf in the bottom of the tank compartment so I can velcro the battery in. I am also leaning toward using a separate servo for the nose gear steering. I'll try to post some pics on the next reply.
Happy Flying!
Loopman
