RE: Engine Mount: Bolts or Screws?
I dont think I would try it on an aluminum mount.
I think the reason the screws work well in the glassed filled is because you drill the hole a bit smaller than the screw and its a nice snug fit. With aluminum you wont get that.
I normally drill and tap all my mounts but all my flying buddy use screws and I have never seen one come loose (although I have had bolts in a tapped aluminum mount come loose)
