RCU Forums - View Single Post - Help Tail pipe distorted/melted ???
Old 09-16-2008 | 06:14 AM
Mavrik!
Default RE: Help Tail pipe distorted/melted ???
Thanks for reply guys.
I sleep when you are awake here is OZ sorry.
Yes 2 degrees measured by incedence meter. I did not think this was much, but if you stare at it long enough you can just see it. I did this to get the correct thrust angle at the exit of the pipe for neutral model thrust FE F16.
It did distort badly in the direction of the 2 degrees however, so this must be part of it. But come on as you say barely visible by the naked eye so I am sure others have plus or minus 2 dgrees.
1 inch from the rear of the outer tail cone of turbine Falcon 100 23 pounds. This is the manufacturers specs 1 inch min to 1 1/4 max gap to bell mouth.
I bot the digital verniers out and get approx .15mm stainless thickness. I am thinking this is too thin for the job or poor quality. I have never heard of anyone else having this issue???
FE are going to send me a replacement if I pay for this shipping. I just hope I do not have the same issue???
I was planning on patching this one so I could at least do the maiden in 2 days. What you think????
Mav[8D]
