RE: The painting of a Tamiya Jagdpanther
Gas cans are a pain to use and one can wont paint the base coat on a 1/16 tank if you have a look on evilbay you will find a mini compressor I think they are about £50 this sounds a lot but you will probably use 4-6 gas cans on a 1/16 tank these will pay for the compressor and you will be able to use the compressor many times and sell it later if you wish as for the air brush go to the window open it and throw £25 out as they are less than useless if you just want to paint one or two things then the least I would use is a Badger, the Iwata is better and you can get one from evilbay for around £50
