RCU Forums - View Single Post - 9650 and GY401 setup
Old 09-16-2008 | 10:16 PM
Dirt_hawg
Default RE: 9650 and GY401 setup
I also have a 9650 401 combo..use the horn with the least amount of distance...In other words get the ball link closest to the servo shaft as possible..I used the round horn and put the ball in the closest hole to the servo shaft...As far as the Tail drifting, you shouldnt have any...Check out all of Finless bobs vids...Are you sure your gyro is in HH mode...Make sure your light on your gyro is always always on and not flashing...
