RCU Forums - View Single Post - CLPR's choice of airfoil on the osmose.
Old 09-16-2008 | 10:41 PM
xcead
Default RE: CLPR's choice of airfoil on the osmose.
the reason of laminar airfoils, is that the wing always has laminar flow over the all surface. the wing can fly faster, and at higher AoA and the flow will always stay laminar, or most of the time...
as the flow reaches high speed in the widest section, and the drag decreases the speed of the flow, causes it to separate itself from the wing, if the widest section is closer to the trailing edge, the turbulent flow that may appear, will stay little time over the surface of the wing
less drag ,less turbulence, and most important the wing generates more lift in all its surface
im sorry if my english is turbulent...
if anyone has other opinion, let us know!!
