RCU Forums - View Single Post - Cowl ring help
Old 09-17-2008 | 04:37 AM
VeeAte's Avatar
VeeAte
Default RE: Cowl ring help
While we are on the subject of cowl rings.
I am putting together a Sea Fury ARF and it includes a ply cowl ring. The instructions dont show how this is put on the model..
Do I glue the ring into the cowl then use screws to screw the cowl ring to the fuse?
If so whats the best way to make sure the cowl will sit straight etc?
I was thinking of inserting the wooden ring into the cowl and lining everything up. Then put a couple of drops of CA onto where the cowl ring sits on the cowl.
Once this is set use 30 minute epoxy to glue the ring onto the cowl fully??
If I am way off track let me know.
Dont want to stuff this up.
Or is the cowl ring there just so the cowl stays round when its screwed to the model?
