RE: Perry pump?
The one way valve will only restrict vent air, better to route the fuel line to the bottom of the cowl. In fact I wouldn't use a pump at all. I would simply set up the system with a uniflow setup and set the tank centerline slightly higher than the carb. To load up bad inverted means the tank is too low.
