RE: glue for foam to foam bond
Gorilla glue is the best glue I've found for foam repairs. Use it sparingly, spritz it with water, and make sure the joint is taped together tightly. The gorilla glue will expand into the surrounding foam. The joint will be stronger than the rest of the foam.
Brad
