RE: Prop size question
You could always turn a 3 blade prop. I believe DaRock has a picture of his with a 3 blade on it and it looks terrific. A 3 blade will shorten the length of the blade by 1 in. If you would normally use a 13x6, with a 3 blade you would use a 12x6, and there is more clearance. Good luck!
