RCU Forums - View Single Post - Angel S EVO Build Thread
Old 09-17-2008 | 11:10 AM
  #285
jadamian75
Default RE: Angel S EVO Build Thread
Wow, Thats a nice Axi set up. The motor is only 2 oz heavier but you amp consumption is maybe I am guessing around 60amps at full throttle according to the axi website. How is the speed in level flight and vertical climbs? I am at 5500ft elevation. Scorpion is sending me a replacement ESC 6 cell switching 120Amp. I ordered a 4025-12 with 6S lipo and 16-10 apc-e should be 78 amps at full throttle (motor is rated at 85amps max) It should stay very cool. The Watts 1747 pitch speed 76.5mph, prop speed 8082 rev. and thrust 225 oz or (14 lbs). I am hoping this set up will work well and not give me very short flight times. The amps seem consistent with what some have reported with the hacker setup but I think this setup will keep everything cooler.
