RCU Forums - View Single Post - Angel S EVO Build Thread
Old 09-17-2008 | 11:27 AM
  #286
BaldEagel's Avatar
BaldEagel
Default RE: Angel S EVO Build Thread
ORIGINAL: BaldEagel
ORIGINAL: jijohans
How long fligth times do you have? On what battery? Is the Hacker A50 -16s a good choice on 6S, was thinking of 6S 4350FP and 16*10 prop...
I use an AXI 4130/16 so I can't comment on the Hacker, with the 4350FP 6S on a 16x10 APC I can get 9mins of all out holigan flying or 12mins of straight aerobatics.
My canopy also required two fingernails to pry open, eventually you will break off the lower edge of the canopy, and the rear overlapping section will also break off, be warned spare canopies are a bit like hens teeth, i.e. don't exist.
Simple sliding catch in the canopy solved the whole matter, catch secures the canopy and the bent over arm aids the removal.
Thought you may like to see a couple of pics of the IC version as well, please don't take any notice of the throttle link, it was temporary to set up the regulator.
Mike
Jadamian75
level flight and vertical climbs are all you want or need, it will pull out of a verticle prop hang no problem if that is your bag level flight and knife edge just go on for ever, the suprising thing about all this is I am pulling about 60 amps at full throttle with a fresh battery, but then again I fly at sea level, in fact I think part of our site is below sea level, well it certainly seems like it when the tide is in. LOL.
One other thing mine came out under 6Lbs, don't ask why I don't know.
Mike
