RCU Forums - View Single Post - 42cc poulan won't run
Old 09-17-2008 | 12:01 PM
av8tor1977's Avatar
av8tor1977
Default RE: 42cc poulan won't run
Well, yeah, .018" is way too much gap. The cylinder must be really worn if you received the correct ring. The stock spec is around .003" or so, but Frank actually recomends a gap of zero. An option would be to send the piston and cylinder to Frank and see if he thinks a custom made ring would save the engine or if it is just plain worn out.
If you have a compression gauge, anything under about 70 lbs. of compression makes a two stroke engine tough to start.
AV8TOR
