RCU Forums - View Single Post - Bad plug during break in
Old 09-17-2008 | 01:56 PM
flyX
Default RE: Bad plug during break in
why do you add stuff to your fuel to create more gunk ?
Why do you buy higher nitro content fuel and dialute it with oil ?
Why not just buy lower nitro content fuel to begin with ?
I mean, if you go to the trouble if trying to prevent wear and tear on your enigne..then crank it over after a crash...what's the piont ?
Yes plugs are expensive. Generally i replace the plug after a break in or use a break in plug...if it last.lol
I also use plugs with idle bar for break in. It helps a little bit in preventing particles from hitting the coil and killing the plug.
