RE: Joe and Ed's Weedy FX26 Xtreme gassy boat. Mono hull
your wood mono looks good joe, I can tell you were off set the strut to the right side by about 1/8", that way would reduce the prop walk, the best solution is use a tapered blade, it will make your boat run dead straight. BTW, will you use the marine epoxy to seal over her?
