RE: Saito FA-100T compression
Hi Donkey Doctor
Many thanks for the info. I primed the motor with diesel fuel (as a solvent ) and the compression has increased. What you and the other members say is correct. The motor must be gummed up because we suspect that it has been stood up with fuel (castor) inside it. Will try to get it going this weekend and will let you all know the results as soon as I have them.
