RE: Bantam BC6 vs Hyperion EOS0606i
[quote]ORIGINAL: RC Accessory
With the Hyperions, you must connect the battery to the charger in a specific order or you can blow the balance circuit. This is mentioned in the Hyperion manuals but only came about recently. Also when you use A123's, it requires the balancer be connected. None of which is required for any Bantam unit.
Thanks for the input guys.
RC Accessory, this is the type of info I was looking for. Looks like I will be getting the Bantam. Thanks again.
Scott
