RCU Forums - View Single Post - Polyester Resin instead of CA and Epoxy
Old 09-18-2008 | 12:19 PM
Mike SVOR
Default Polyester Resin instead of CA and Epoxy
Has anyone ever used polyester resin (fiberglass resin) to build their plane?
I'm about sick and tired of the current quality of two part epoxy resins (like 20 min epoxy in the twin tubes).
I've always had great luck with wood and fiberglass resin in the past ( on my real boat), so I think I'm going to build my new HoB P-51 using poly resin instead of CA glue.
I'm sure i'll have to use CA glue to tack some pieces in place, but will finish with poly resin on all joints and such.
It dries Better and Harder than 20 min epoxy (which dries kinda rubbery). And poly resin is very strong.
Thoughts?
