RCU Forums - View Single Post - Fliton Element 170 ARF build
Old 09-18-2008 | 01:35 PM
patternflyer1's Avatar
patternflyer1
Default RE: Fliton Element 170 ARF build
Other things I will use. Weights in grams again.
Hacker C50 14XL with collet, prop washer and prop nuts 577
Jeti 90 102
22x12 116
TP 2 cell 910 Prolite 46
Jaccio 6v regulator 11
Tru turn spinner 42
Budd mount front 38
Budd mount rear 9
Airtronics 92186 Pcm receiver 44
Airtronics 94758 digital servo (rudder) 58
Airtronics 94761 mini digital servo's (aileron's and elevators) 20g each x 4
Flight Power 5350 F3A 1175
Bolly gear 128
Aluminum axles (?)
SO right now, I am at 4924. Plus a few things like servo screws and arms, servo extensions, putting wiring in for a shunt, pull pull setup, battery velcro. As stated, there are several areas I can lose a little so I think I can make weight with it. Time will tell.
