low needle speed question?
TTPro .36
the manual says to open the high speed needle 2.5 turns as a starting point. Ok, thats fine.
Is there a "starting point" for the low speed screw?
If I remember correctly it says " turn 30 degrees at a time not to exceed 1 turn. " ??
When I was fooling around with it I kept track of my movements and could return to the original position.
With the help I've had its been moved.
Is there a "starting point for the low speed needle.
I'll ask for advice at the field on Saturday....
But I think new "dry" fuel will fix most of my problems.
Steve
