ORIGINAL: gunfighterII
Hover,
I went looking for the post on the 3305 and I found one in 2004 that Krysta says you can use it in airplanes, then I found a post in 2008 that she said they are not recommended in planes due to deadband issues. Then I found this post which might explain your problem better,
http://www.rcuniverse.com/forum/m_22...tm.htm#2211319
Hello gunfighterII.
Thank you for feed back me this issue. [sm=thumbup.gif]
In fact, I got this information some times ago, after burn 3 3305. Right now I am not using them anymore.
The 3305 has the draw problem, and also a motor that's not precise for airplanes usage.
3010 is my option for mid-sized 3D glows right now!!!!
