RCU Forums - View Single Post - Fliton Element 170 ARF build
Old 09-19-2008 | 01:53 AM
patternflyer1's Avatar
patternflyer1
Default RE: Fliton Element 170 ARF build
Yes I am planning on removing some of the beam slots. I also thought of removing some of the firewall. Although there's no need to do this for cooling on this plane as the batteries will be either on the wing, or under the gear. So I would put clear covering over the holes that I make in the firewall.
Time will tell really. Right now I'm placing an order with Central for some hardware. The stock stuff is ok, don't get me wrong, I just like what I always use.. That's the only reason I am replacing it.
Canopy came out good. Did you notice it's the same color you use Derek? Thanks for that.. lol
Chris
