RCU Forums - View Single Post - PORTING RYOBI 31
Old 09-19-2008 | 12:03 PM
av8tor1977's Avatar
av8tor1977
Default RE: PORTING RYOBI 31
Some of the Ryobis come with very short exhaust timing and definitely respond to more. The only way to do it right is to get a degree wheel and check it out. Shoot for around 150 degrees. Go slow, and take off a little at a time and keep checking the timing until you get what you want. Then be sure to chamfer the port edge slightly so as not to damage the piston and/or ring.
AV8TOR
