RCU Forums - View Single Post - CMP BF109F BUILDING THREAD
Old 09-20-2008 | 05:12 AM
  #224
Schummie
Default RE: CMP BF109F BUILDING THREAD
Hello Dave WWIIP38,
Did you use the rest of the air-retract gear that was included in the set with your new retracts? Or do you consider this no good as in terms of quality? Are your retracts air up and down, or spring down?
Further, as I'm trying to use a OS 120 AX, I/m already running in exhausts problems, becouse there is only one way to place the engine. I prefer not to stick out a huge standard muffler out od the side of the plane. Anyone already solved this?
Regards,
Eric Schumacher, Netherlands.
