RE: Bantam BC6 vs Hyperion EOS0606i
FWIW,
i'm using the Bantam and it has been the easiest charger to use in terms of set and forget. i feel totally safe with this charger. one thing you will find out about Evan is that should you have an issue of any kind, he'll make it go away in the blink of an eye.
great customer service, and Evan has a trick up his sleeve for virtually any way you want to configure things.
