RE: Eflite Blade CX2 Help
If it's now going in reverse, then you have turned the pushrod too much, turn it back a few complete turns.... and you shouldn't move the location of the pushrod to the servo from the hole that is closest to the servo... moving that forward will give you greater responce on inputs from the TX. thus making it MUCH more twitchy and harder to handle...
Good Luck!
