RCU Forums - View Single Post - Perry pump?
Thread: Perry pump?
Old 09-20-2008 | 11:58 PM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: Perry pump?
If you're still having mid-range trouble, it's probably due to the pump setting. With a pump, the low needle affects the low end, the high speed affects the high end, and if you're bogged down in transition the pump is probably too rich. Turning the adjustment counter clockwise decreases fuel flow (counter-intuitive - you're releasing tension from a spring, not opening a valve).
