RCU Forums - View Single Post - Sig Rascal 110
Old 09-21-2008 | 02:46 AM
freeair
Default RE: Sig Rascal 110
ORIGINAL: S. Christensen
Temple,
FWIW, we have several Rascal 110 models here at SIG that use larger engines - 2 with Saito 1.50's, 1 with an O.S. 1.60 twin and one with a Saito 1.80. I'm happy to report that all of these models have literally hundreds of flights on them, all with no issues what-so-ever. These models land perfectly, take off perfectly and do serious pilot stuff inbetween. We also fly from a grass field and all of our models use the wheel pants - the ORIGINAL wheel pants. I wouldn't even think of flying without wheel pants - those are part of the "look" for goshsales! The Rascal 110 is about as much fun as you can have with a model of this size. It will do most anythng and does it with style. Folks who complain that they can't get this airplane to land because their engine has too high of an idle, probably need to learn how to properly adjust the carburetor or use the correct fuel or replace the glow plug. Have fun.......
Scott Christensen
SIG Mfg. Co., Inc.
it would be nice if good old SIG Manufacturing could use a little more glue of the correct type when it comes to the Rascal 110, a friend has just set this model up and within 3 flights he noticed the main engine mount builkhead was loose , close inspection reveiled the engine bulkhead had seperated [ thanks to glueing ] from the 1/4 x 1/4 inch longeron fuse pieces that surround this bulkhead. not sure of the glue used but there wasn,t much and it certainly didn,t do its job, big plane big engine small glue job, no no.
