need help on starting
oic. so do you think that's the problem? so if i change the glow plug, it will start easily?
i've got another question since you have a fusion too. my problem is some fuel comes out of the starting screw, just behind the washer. i think the reason that happened is because at first i forgot to put the drills torque to its lowest. so i dissaembled the E-start then found a ruined O-ring just behind the washer. that's why there's some fuel coming out. what do you think?
tnx for the help
