RE: prop!
The usual way of balancing a 3-D plane is to fly at about half throttle and then roll over up-side down and then the plane shall fly straight or just barely drop down, if it rises it is too tail heavy. You should be able to hover even if you have less than perfect balance, I`m really not sure just what your problem might be? Maybe you just need more stick time??
