RCU Forums - View Single Post - Help Tail pipe distorted/melted ???
Old 09-21-2008 | 03:36 PM
lookilook's Avatar
lookilook
Default RE: Help Tail pipe distorted/melted ???
hi,
unfortunately i am the one who melted 3 tailpipes by fej on my fej f16 and yet dont know the reason .as you can see from the pictures taken damage is huge.already thrown 2 of them in the dustbin but i hold the third as damage is less and at the front only and i am thinking of making one ground run with this installed and see what happens.thanks to chris (wren rep in cyprus) he gave me new pump-ecu-and an mw-54 to eliminate possibilities of faulty items.
length of the tailpipe(dualwall) is 58cm without bellmouth.outer pipe extends past inner pipe by 1.5cm .
TAM,if you can make one for me reply to my topic or pm me.
anyone with suggestions as to why this has happened be my guest!!
rgds NIK
ID:	1037543   Click image for larger version
ID:	1037544   Click image for larger version
ID:	1037545   Click image for larger version
