RCU Forums - View Single Post - Thinking about electric in my next pattern project
Old 09-21-2008 | 05:08 PM
Neo02's Avatar
Neo02
Default RE: Thinking about electric in my next pattern project
Ciao Stek,
ORIGINAL: stek79
I see in that the AXI F3A costs less than a half a Plett 30-10 EVO! Do you know why is there such a big difference? Flight performance are comparable? If not, in what the Pletty is superior?
check out the weights: 585g for the Plettenberg against 652g for the Axi. Plus you get a much better efficiency, that means running the same RPM with lower Amps on the Pletty. But if money is important, then the Axi will certainly do. There are some electrical differences in both setups, but I'm not that much of an expert to tell what this difference really is.
Regards
-Fabrizio
