RE: Guillow's #303 Piper Super Cub 95 Build
Didn't get the wings completed but made pretty good progress today. I don't know if it was mentioned in this thread or not but I got a good tip from someone regarding getting these die-cut parts out.
If you sand the back of the parts sheet before trying to get the pieces out, it helps immensely! I was able to get all the ribs out without any problems. There tabs for the stringers are just as bad as the fuselage former tabs were but it was A LOT easier over all. Once again, I used an angle to make sure the ribs were 90 degrees off the building board while the leading and trailing edge were pinned down.
Hopefully I can finish up the wings over the next few evenings and move on to the tail.
