RE: suspension travel
the truck is actually designed to bottom out or chassis slap over jumps.....It spreads the impact over the entire chassis instead of all on the shocks. If you go too stiff you will start breaking shock ends and bending shafts,,,,If you are still using the stock shocks the tops will blow right off with a big jump if they are too stiff(ie:when using heavy weight shock oil
